Looking for some part numbers.....
Old 06-11-2010, 08:27 AM
CarolinaCamaro's Avatar
Question Looking for some part numbers.....
for front transmission seal on 2001 4l60e ls1
rear main seal on same
also, should I stick with dealer parts or would fel-pro be ok?
Also, wondering what would be easily replaceable as far as seals and wear parts as I will be having the transmission out for a bit. I don't want to dig into the internals though. thanks
Old 06-11-2010, 12:16 PM
Kevin01Z28's Avatar
Good site. Whats the part number for the input shaft o-ring?
Old 06-11-2010, 02:46 PM
Kevin01Z28's Avatar
Originally Posted by Bro Inc
The orange one? The only place I've found that is the dealer.
I've had trans shops and other places, even bulkpart give me the green o-ring. Maybe it will work, but it was originally used on the V6 transmissions with a smaller ID input shaft, so when you put the green o-ring on an LS1 input it stretches it out a little which reduces it's OD when it's on the shaft.
Guess ill just have to get one at a dealer then. Using a smaller one probably wouldn't help my situation any.
