torque converter problems.. i think..
Old 08-03-2010, 07:34 PM
Wicked Mayhem's Avatar
Default torque converter problems.. i think..
just finished putting my 5.3(from a 2002 silverado) back together.. bought a torque converter off ebay stupid cheap..
GM 4L60E 30 Spline 2,200 Stall 1985 - 2002 (Some later models also) Lock-Up Torque Converter
i slid it onto tranny to make sure it fit.. it slid up on there. felt like it clicked up in there all the way. there was about 3/4" between where the verter would sit against flywheel, and where the tranny would mate to the engine.
i go to put it all together.. bolt tranny to motor.. that goes fine. go to turn verter to line up the bolt holes.. cant budge it.. i can barely turn motor over by hand with no spark plugs in it. loosen tranny bolts up, motor and veter spin freely..
just to double check.. there isnt a plate that goes between motor n tranny right? it has the stock flexplate from a 2002 silverado..
my dumb *** didnt measure anything on the motor side of things.. i guess i should pull tranny n see how that **** measures out..
Old 08-03-2010, 08:15 PM
Circle-D's Avatar
Sounds like you might have a LT style converter. Measure the OAH, overall height. From the converter pad, where it bolts to the flex-plate, to the top of the hub, the parts that goes in the transmission.
LT = 5.900-5.950
LS = 6.500-6.550
Hopefully you just did not stab it all the way.
Chris
Old 08-03-2010, 08:19 PM
yeah im getting like 5-15/16 on the verter.. ****.
and yes, i had the tranny all bolted together to the motor.. fml
Old 08-03-2010, 09:25 PM
Circle-D's Avatar
Shall we get started on a converter for you.....
Seriously though, if you need us just call or PM.
Chris
