out seal leaking ...2000 Z28
every morning theres a big puddle of tranny fluid under my car
it's leaking out that seal where the drive shift goes in
output seal I guess..can I fix this at home or
will it be a big job?
newbie to a camaro here
Thanks!
Thanks!
at home , easy fix
remove drive shaft, use a small screw driver to work under one side of seal make one side collapse, pry it out, insert new seal tap it in with a small punch or any blunt screw driver( be sure and start the new seal the correct side in), you will loose some oil, if possible rase the rear of car so you do not loose so much fluid. REMENBER to check/add fluid
Johnny
Johnny
