A bad day....
A bad day....
well just thought id post up for some encouragement and help. ive had my formula 98 a4 for 4 years no motor or transmission. in the past 3 months ive put a rebiult heads/cam ls1 in the car, and a built 4l60e with the help of a good friend to me. so today in san antonio the weather wasnt cooperating
rain of course and in the mix of trying to fire the car for the first time in 4 years i find out, the rebuilt starter is no good(armatuer not coming out) it happens and its no ones fault it just sucks. so i say forget it put it back on the ground and come to find out (also just installed drive shaft and filled the
transmission today)that the car wont move any more.checked the e-brake, its ok not sticking. so basically im saying its the transmission. what did i do wrong? ive got the shift linkage correctly installed facing downward. but no matter where i put the manual rod the car wont move. i guess im going to have to drop the pan.maby a parking paw problem or something. just seems like im never going to get this car going. any insight or if someone has had this same problem lemme know!. the car has never turned over only rotated by hand also.
I've seen it a million times on here, very common when an engine and trans is put together the pump gets broken. Take the bottom cooler line off, start the engine and see if fluid comes out.
Then again the trans is rebuilt, it could be a problem with that too.
the engine doesnt run yet, this is with the engine off, i know what i did, i made sure to be carefull putting the trans in, its something with the manual rod or parking paw, will pull the pan off tommorow. thanks for the input though any help is always appreciated!!
the brakes werent locked, it rolled with the driveshaft un hooked, and i was the builder, the rod was disconnected from the selector now it disengages.all fixed now
