TH400 and a B&M deep pan cable bracket
Old 10-29-2010, 09:08 PM
MUSTANGBRKR02's Avatar
Default TH400 and a B&M deep pan cable bracket
Just got the Th400 in and installed a B&M deep pan and the cable bracket that came with the Hurst shifter (pistol grip 1/4 stick) will have to be modified to clear the pan. Anyone else have this problem?
Old 10-30-2010, 06:08 PM
I ended up cutting the bracket and modifying it to fit.
Old 04-05-2013, 02:27 PM
93camaro_zzz's Avatar
I know this is a pretty old thread, but you wouldn't happen to be able to take a picture of your cable bracket installed on your tranny would you? I am having the same problem as you. I have the hurst shifter, B&M deep pan and TH400. I modified a bracket to fit also, but my car won't shift to 3rd gear. It is a RMVB setup. I am pretty sure it is this bracket dilemna, but I want to make sure. Thanks,
Jordan
Old 04-06-2013, 06:00 PM
I would but I am two 4l80e's past the 400. lol. I just ground down the bracket to fit. Make sure that the cable is adjusted properly.
Old 08-06-2022, 03:50 PM
Racer2646's Avatar
Jordan
I know this is a reach but would you have any pics or can get some of the bracket you modified to fit your TH400 with B&M pan with Hurst shifter? I know it's been awhile but I'm losing patience with this exact same setup. Thanks man. Mike
Old 08-06-2022, 03:51 PM
Racer2646's Avatar
Jordan
Quick Reply: TH400 and a B&M deep pan cable bracket
