how much for a ss3600 stall run me?
Just wondering how much a ss3600stall would cost? And what other nods would I have to do if I do install the stall?
Speed Inc has a group purchase sale going on. Your going to want to get an aftermarket trans cooler thats rated at around 22k
https://ls1tech.com/forums/midwester...verter-gp.html
Transmission cooler, not intercooler. B&M makes a good cooler (called the Supercooler) I believe.
Most people would recommend that you get at least a 3.23 gear ratio with that stall, although I'm sure that there are a few people using it with 2.73s. It will feel very loose and build up a lot of heat in the trans with numerically lower gears.
