4l60e valve body?
4l60e valve body?
im rebuilding 4l60e out of 97 firebird during valve body dissembly i laid each valve exactly the way they came out on shop towels well in accidently bumped into table and valves fell off into floor i am needing to know if anyone has diagram for that yr model my atsg manual covers like 95 or under the side with the shift solenoids and force motor didnt fall off its the side with the pwm solenoid and 3-2 downshft
Shift solenoid needle or rod
I will post an image later tonight if no one else has already.
The images you are looking for, are actually in the ATSG "update-guide" for the 4L60E transmission.
This is separate book from the one you currently have.
Use the valve-train image that you have for all valve-body components, less the TCC valve-train, and 3-2 control valve-train.
Here is the 3-2 control valve-train:
And here is the TCC valve-train:
The following users liked this post:
NZLS1 (08-27-2021)
NOTE!!!
Even though the image/ ATSG book refers to this valve-train and solenoid...
As the "3-2 Down-shift" valve-train...
It is NOT!
The image is of the "3-2 Control valve-train".
It is NOT!
Damn it!
Old thread!!!
Old thread!!!
MaroonMonsterLS1 (08-24-2020)
vorteciroc (08-23-2020)
vorteciroc (08-24-2020)
