no reverse.. ??
Old 01-16-2011, 05:58 AM
rhinosarge's Avatar
Default no reverse.. ??
4l60e .. swapped into lq9.. stock stall
no shifter in yet..
the forward gears work..
i have the truck lifted ... cant find reverse? or it wont move into R ..
trans has been sitting for a 1.5 years..
the cooler lines arent plugged to cooler.. juss re-circulating for now
any suggestions??
Old 01-16-2011, 10:06 AM
Jays_SSZ28's Avatar
Did it have reverse before the swap? Or was this transmission just purchased from someone who might have sold a non working trans?
Old 01-16-2011, 12:26 PM
racerrit's Avatar
Reverse is usually the first to go in 4l60, id say its time to freshen it up! if it sat for 1.5years thats not good on trans by any means
Old 01-16-2011, 12:49 PM
Predator T/A's Avatar
if its been sitting for a while its possible that the reverse boost valve is stuck.
Old 01-16-2011, 03:26 PM
rhinosarge's Avatar
thats what someone told.
to run in the street in Drive until it shifts to second atleast.. but the truck is barebones.. juss a cab and motor.. so im scared haha
it was from my mechanic who had this trans in a built camara.. so i know it worked before. but it has been sitting a long time.
so what to do.. any suggs.. should i put the rear end on jack stands and leave in R for a while idling
