1999 vette auto trans question
Can you put a bellhousing and a tailshaft on a C5 4l60e trans might have to change output shaft and use like a regular trans???. any trans gurus???
Moderator
In addition to the info above, there is also an issue with lube in the back of the case to lube the extension housing bushing. If one were to make an abortion of an extension housing this would have to be taken into concern.
