E40 ECM 4L80E conversion no speedometer
Well as the title states... Doing a custom swap but ran into a little prob..the vehicle is a 2004 Colorado lsx conversion running an E40 ECM and put a TCM from a 2008 Chevrolet express 2500 ... We got it to shift but no speedo.. Can anyone please help me with this.????
everything is connected and reluctor is fine.. when i put the 4l60 program the speedo works.. once i change it back to the 4l80 program it doesnt.. can anyone please help.. im willing to pay someone that can help us get this truck up and running.
no we are using HPTuners.. i read somewhere that there is a write up with instructions here on ls1tech on how to do the conversion using the E40 ECM and the stock 4L60 TCM.. but havent had any luck finding it.. supposeably you just have to re pin a couple of things.. that would be awesome.
Gingervitis Addict
here is the tune.. please let me know what can be done.. if you want call me to 956-517-0262 if you have info... thank you.
ok no its not.. didnt let me.. file to large.
I'd love to be able to help you, I have so far only done the 4L60E and manual trans swaps into the colorados. I make harness for those.
How did you program the TCM/PCM? The 2008 can would that be a T42 as well? You have to write the TCM and PCM together with GM TIS, before you can properly read right with HP tuners. You can sometimes write with HP but certain functions will be missing throttle control and, maybe vehicle speed?
The the 08 van would have had a E38, not a E40, I don't know that you will get them talking to each-other properly. You can flash a manual tune into the E40 and run the speed signal into the E40, speedo would work, but then I don't know weather the TCM/PCM will still function together. The TCM/PCM communicate via Can hi/lo, then the PCM sends the speedo message via serial data.
Are you getting any error codes? Can you log speed with HP tuners scanner?
http://www.performancetrucks.net/for...7/#post4157222
4l60E to 4L80E
now the tune part maybe tricky. Are you using a 06 trailblazer tune? If so re-flash the T42 and E40 with a 06 trailblazer SS, it will have the I.S.S input senser. In the above link the computer pins are different I can tell you how to pin them to the T42 instead. Then you just need a good tune. You cannot perform segment swaps on E40 pcms and up, like you could on he LS1 style PCMs
4l60E to 4L80E
4l80e, colorado, conversion, e40, ecm, front, gm, iss, location, put, rear, sensor, speedodmeter, speedometer, tcm, transmission
