Hurst pistol grip in 6 speed console
has anyone done this? ive searched up and down and still have found nothing i want to be able to put this in my 6spd boot thing but im not sure it will fit with the trigger on it as well.
thanks guys
thanks guys
You will have to cut pretty deep, your better off getting an auto upper console, it will look way better. But you won't be able to use the square whole, the pistol grip has to sit much further back
You use the trigger to get out of park, reverse and to shift into 3rd...or first. Depending on valve body. Then going forward you have to use the trigger to go into neutral and what not. I dont know What shifters would fit in the square whole. It's the range of motion that's the problem. Plus sitting so far forward, it will hit the dash, if it's in where the stock shifter is. The pistol grip has a more solid feel then the ratchet shifter. Might just be personal taste. Plus the ratcheting got old...
