Did I install my trans cooler right?
I put the trans cooler in yesterday. Here's how I ran it. The line comes out of trans to the top of the rad. Then from the rad to the b/m trans cooler. then out the other side of trans cooler back to the tranny. Is the the right way to install the lines?
The bottom line from trans to radiator is the feed to the radiator and top line from radiator is return to trans. If I read this right then you have the fluid going to your external cooler first and then the stocker. Should be the other way around.
I dont use my stock cooler. I have the bottom line (fluid coming from trans) going into the bottom of my external cooler and top line of external cooler going back to trans.
