t-56 to 4l60e
Old 07-14-2011, 11:53 PM
mattmatt350's Avatar
Default t-56 to 4l60e
I am going from a standard to automatic. I have a 4l60E and i want to put the trans-go 3 kit in it because I want a manual valve body. This the advise I've gotten anyway and my question is, will the transmission still be electronically controlled? And if so will I need some sort of PCM like a optishift? I dont think I do but the trans go kit seems like a PCM is necessary. After all the "E" in 4l60e stands for electronic.
Old 07-15-2011, 02:26 AM
01ssreda4's Avatar
What year car/harness/computer/transmission?
Old 07-15-2011, 11:02 AM
RARON455's Avatar
Easiest way will be to swap out your pcm with one from an auto car of the same year. Of course this is if you are on a stock setup on the engine.
Old 07-15-2011, 09:32 PM
my car is a 99 z28 and im not sure what year the transmission is but i know its a 4l60e. I was hoping that going to a manual valve body would eliminate any electrical as my computer is for a standard and has no transmission info. If its not possible I guess my best bet is going to a th350 but I really wanted 4th gear.
