4L60e forward clutch backing plates?
Old 08-24-2011, 09:22 PM
thebufenator's Avatar
Default 4L60e forward clutch backing plates?
So I am rebuilding a 4L60e for the first time, and am having a clearance issue with the forward clutches. I am measuring about .074 of travel at least. Maybe a little more.
My backing plate is marked 'C'. Is GM the only source for thicker backing plates? Is that the only way to take up some clearance?
Thanks
btw, I can't find any backing plates.....
Old 08-25-2011, 12:48 PM
Nobody has a source for part numbers? Nothing? Entirely new topic?
Old 08-25-2011, 11:56 PM
zgp
zgp's Avatar
Dealer item, if not go to Transtar or Dacco transmission parts.
Old 08-26-2011, 08:29 AM
11 Second Truck Club
L-EATER's Avatar
Try looking up whatever it takes transmissions.....
Old 08-26-2011, 09:45 AM
Whatever it takes seems to have apply plates and pressure plates. I am assuming the pressure plate is also the backing plate.....right?
If so, is there a difference between 700r4 plates and 4l60e plates?
btw, if anyone has a good technique of getting the damn reverse input piston back in the drum, please let me know. ****** won't go in without bending the outer seal. ******* ******
Quick Reply: 4L60e forward clutch backing plates?
