4l60E trans problem please input!!!
Hey guys well i just rebuilt my 4L60E. I took her for a drive around my shop everything seem well couldn't get into OD to much traffic. On the way home i noticed that it will not go into OD unless i let of the throttle and get back on but the second i give it 20%-40% throttle to over pass someone it slips back to third and third slips also a bit. I got of the highway, I got on it 1st - 2nd felt AMAZING but when it went to shift into third NOTHING rev limiter??? WTH is going on here when driving normal 1-2-3 shift fine. Please anyone help me out Thanks....
P.S.
The trans was rebuild do to a needle bearing failure.
EVERYTHING is new inside TCI Pro Kit, Transgo Shift kit, New oil pump from GM, And seals Vacuum Tested all clutches, pump, servo, valve body.
Any input would be great i dont have much money spend on a $2000 trans so please dont get crazy lol. I just would hate to have to pull this damn thing out again.... My guess is the 3-4 accumulator spring is too weak??? or too stiff???? or a solenoid issue???
P.S.
