LQ4 - What 4L80E do I use?
I have a 2005 LQ4 but it did not come with a trans. I was told it was from a Denali which would mean I need a 4L65E. Everyone suggests running the 4L80E for strength though. If I use a 4L80, what years can I use? What needs to be done with the tune and harness?
Along with the propper bolt pattern, the 99+ 4L80e is a much better unit to start with than the early ones. The 4L80e will not simply plug in. Depending on your power output a 4L80e is probably not really required for your application and will just add extra cost.
If you already have a 4L80e or you are planning on 600-700hp in your truck check out http://www.speartech.com/ Click the "Adapter harness" icon and scroll down to the "4L80e upgrade harness". That is what you will need to convert your 4L60e harness to opperate a 4L80e. Then you will need your ECM reprogrammed to conrtoll it.
One last thing, are the electronics the same in the 60e and 65e? Thanks!
Not trying to seem like I'm calling you out or anything, just curious.
