T56 to TH400 Conversion Wiring
Old 04-14-2012, 05:23 PM
StraightTimeStirrups's Avatar
Default T56 to TH400 Conversion Wiring
I am doing the conversion and am wondering what wiring needs to be tweaked. Things such as Neutral Switch etc. If you can tell me where to look and what needs to be jumped etc. I would appreciate it.
Thanks,
Joe
Old 04-28-2012, 10:00 AM
Duffster's Avatar
You take the switch/wiring from your clutch depressed and make it your park/neutral safety. Your reverse is still your reverse, but relocated. I did this exact swap last year and while I miss the shifting myself, the consistency is mighty nice! Good luck.
Old 04-28-2012, 10:56 AM
I found that switch and am going to do the wiring today actually! I did find a switch on the clutch that is on the pedal as well that is on the pedal on the back side that makes or opens a circuit when the pedal is not depressed! What is that for?
Joe
Quick Reply: T56 to TH400 Conversion Wiring
