Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Automatic Transmission
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
4L60E | 4L80E | TH350 | TH400 | TH2004R | Powerglide | Converters | Shift Kits
Sponsored by
PerformaBuilt Transmissions
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 05-06-2012, 10:40 AM   #1
Garage is empty, add now
98LS1driver's Avatar
Trader Rating: 2
Default rebuild 3-4 clutch packs clearance prob
im currently installing the probuilt prostreet upgrade kit in my 4l60e thew 3-4 clutch packs are stated to be .020-.035 clearance but im at .010 what can i do to get the right measurement??
98LS1driver is offline   Reply With Quote
Old 05-06-2012, 01:14 PM   #2
Trader Rating: 0
Send a message via AIM to mrvedit
How thick is your backing plate (above the clutches)?
I prefer to always use the thick OEM apply plate (0.223) below the clutches, but a variety of backing plates are available from GM and aftermarket for the purpose of setting the clearance.
I have 0.129, 0.157 and 0.194; others are probably available too. Another trick is to use a thinner snap ring.
mrvedit is offline   Reply With Quote
Old 05-06-2012, 01:31 PM   #3
Trader Rating: 0
Here are the thicknesses and part numbers from the ATSG Update Manual for the backing plates:
24217450 = 0.144
24217453 = 0.165
24212460 = 0.194 (I think is is stock for 6-plate 4L60E)
24217516 = 0.219
24217517 = 0.241
The 0.129 I have is aftermarket:
http://www.transmissionpartsusa.com/...-000035772.htm
I hope that helps.
Old 05-06-2012, 02:57 PM   #4
Trader Rating: 2
ill have to measure it but im going to try to use the stock one now i tried it with the raybestos one that came with the kit
Old 05-06-2012, 03:42 PM   #5
Trader Rating: 2
got it! Was using the oem snap ring which was wayyy thicker lol got it right at .020 now
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
34, 4l60e, automatic, automatics, built, clearance, clearsnce, clutch, clutches, pack, packs, pro, street, transmissio, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
