Trans cooler question
Old 05-11-2012, 03:30 AM
lilblackLT1's Avatar
Default Trans cooler question
Ok so i just ordered a RPM level 5 transmission for my 07 TBSS. My question is i'm going to be installing a B&M trans cooler should i run the lines from trans through the radiator cooler to the B&M cooler back to the trans or straight to the B&M cooler and bypass the one built in the radiator???
Old 05-11-2012, 09:04 AM
maddoglou454's Avatar
I like running both coolers through the radiator to the external cooler, and then back to the transmission. No matter how good the transmission is built, heat is the enemy. The cooler the transmission runs, the longer its life is. Good luck with your RPM transmission, there a great company.
Old 05-11-2012, 02:15 PM
BoxeDK's Avatar
Default Cooler
I often read that the heat kills the transmission.. Then why use the built-in cooler, if you are running with an external cooler?
As far as I can see, the heat from the radiater (with hot water from engine) will heaten up the transmission oil to, if you use the built-in cooler..
Or am I totally wrong on this one ?
Old 05-11-2012, 06:13 PM
mikey67's Avatar
The cooler in the radiator is dual purpose. It acts as a cooler obviously, but it also brings the transmission into it's operating temperature range quicker when there's cooler ambient temperatures.
Old 05-12-2012, 12:43 AM
BoxeDK's Avatar
So for the weatherconditions here in Denmark, what do you suggest?
(Including a lot of stop-go in slow rushhour driving, and a couple of street races a month :-)
We have at the MOST, 100* fahrenheit in summertime, but at wintertime we are way below freezing.. -4* fahrenheit (-20 degrees celcius)
Old 05-12-2012, 01:04 AM
now which line on the trans itself top or bottom is discharge and return i want to put the cooler after it goes through the radiator cooler so i'm not heating up the fluid after it goes through the B&M cooler
Old 05-12-2012, 01:14 AM
BoxeDK's Avatar
So the following:
Trans-out >> radiator oilcooler >> external cooler >> trans-in
Maybe put a small fan on the external cooler, or would it be to much ?
Old 05-12-2012, 03:18 AM
01ssreda4's Avatar
Top is the output....
Old 05-12-2012, 04:09 AM
thank you sir
Old 05-12-2012, 09:42 AM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Thumbs up
Originally Posted by lilblacklt1
ok so i just ordered a rpm level 5 transmission for my 07 tbss. My question is i'm going to be installing a b&m trans cooler should i run the lines from trans through the radiator cooler to the b&m cooler back to the trans
yes!!!
Old 05-13-2012, 02:31 PM
Gingervitis Addict
slow67's Avatar
You can get a tru-cool with a built in thermostat to make it warm up faster.
