Non-lockup converter in stock 700r4
Old 05-21-2012, 02:55 PM
jawsgt's Avatar
Exclamation Non-lockup converter in stock 700r4
I am installing a non-lockup converter in my 93 4l60/700r4 and i need to know if i have to pull that check ball in the front of the inout shaft and what is the valve im supposed to install in it? anyone with a part number? thank you
Old 05-21-2012, 03:46 PM
lt1-xjs's Avatar
Why would you not want lockup ?
Old 05-22-2012, 12:21 PM
BoxeDK's Avatar
Same question as lt1-xjs...
IF you don't want the lock-up function, you can just unplug the electrical wire from the side of the transmission... Then no lock-up... But you have to be sure that your trans is 4L60, and not the 4L60E...
Quick Reply: Non-lockup converter in stock 700r4
