Difference ?between a lt1/ls1 stall/torque converter
Old 05-31-2012, 11:55 PM
Camaro_ZL2's Avatar
Default Difference ?between a lt1/ls1 stall/torque converter
Just wondering what's the difference between the torque converters(4l60e)I have a lt1 looking for a stall between.3200-4000 and I don't want to get the wrong one any hints to know which is which I feel kinda stupid asking this
Camaro_ZL2 is offline
Old 06-01-2012, 09:07 AM
Circle-D's Avatar
Main difference is the height. LT is ~5.950. LS is ~6.500. Several other differences, but that should be easy to spot...
Chris
Circle-D is offline
Old 06-01-2012, 09:27 AM
Moderator
mrvedit's Avatar
Chris
I assume then this is the reason an older 4L60E from an LT engine will not work on an LS engine and vise versa? The key problem being that the newer 4L60e have a 300mm input shaft designed for the LS converter and the older 4L60E have a shorter input shaft for the LT converter.
I'm asking for confirmation/clarification because this question seems to come up every week on this forum and while we know "it doesn't work", I have not been sure of the exact reasons.
mrvedit is online now
Old 06-01-2012, 11:43 AM
Circle-D's Avatar
You can use an LT style 4L60 Transmission and converter combo on an LS style motor, but you need to make a few changes... Either change to an aftermarket LS flexplate with the LT bolt pattern or drill out your OE plate to fit it, LS is 11.080" and LT is 10.750". You also need to either lengthen the pilot on the converter by ~.300" or use an extension sleeve.
Going the other way is not possible with a stock converter. The pilot on the LS style converter is to long and will bottom out in the LT crank before it hits the flexplate. But we can make a custom converter if needed.
I think that answered your question.....
Chris
Circle-D is offline
Old 06-01-2012, 11:55 AM
Moderator
mrvedit's Avatar
Thank you for the detailed info; that sure helps.
Of course I always remind people that taking a 15+ year old stock transmission designed for < 300 ft/lbs and putting it on a 400+ ft/lbs engine probably will not have good results.
Old 04-03-2015, 10:59 PM
zukboi2004's Avatar
So I am understanding this as a LS converter
will work in a LT trans with a flex plate & spacer?
I know this is a old thread, but, the search button works!
Lol
zukboi2004 is offline
Old 04-04-2015, 07:14 AM
Circle-D's Avatar
Lol
Negative... 4L60 LT style trans has to have the LT style converter. But there are was to get the LT converter to bolt to a LS motor.
Chris
Circle-D is offline
Old 04-04-2015, 07:59 AM
zukboi2004's Avatar
An exploration as to why a LT trans won't work with a LS converter?
Old 04-04-2015, 09:36 AM
Moderator
mrvedit's Avatar
An LT trans has a 298mm input shaft while a LS trans has a completely different shaped 300mm input shaft. See the picture in this post:
https://ls1tech.com/forums/automatic...s1-4l60-e.html
An LT trans with a LT converter can be bolted to an LS engine using a GM spacer or a pilot extender sleeve. A recently started a new thread "All about Flexplates, Converters, Transmissions and Spacers":
https://ls1tech.com/forums/automatic...s-spacers.html
Old 09-04-2019, 01:51 PM
02TA3312's Avatar
Chris
How do you bolt a LT converter to an LS?
02TA3312 is offline
Old 09-04-2019, 01:55 PM
MaroonMonsterLS1's Avatar
Received 1,218 Likes on 782 Posts
first off...this is your 2nd post and you're reviving a long dead thread
what's worse...there are threads that cover this already
what's even worse is those threads are in the sticky!!
to answer your question...you need the proper flexplate and spacer. Make sure the trans has the correct input shaft to match the converter.
This is why new users need a 30 day hold before they can post...
MaroonMonsterLS1 is offline
Old 09-04-2019, 02:00 PM
02TA3312's Avatar
Couldn’t find anything about putting a lt converter onto an 98+ (Ls1) 4l60. Hence why I asked.
Really bothers you that much for someone to revive an old thread?
02TA3312 is offline
Old 09-04-2019, 02:21 PM
98CayenneT/A's Avatar
Very much so, especially when you start from the top and read for a while to see what's going on then you notice the thread is 10 years old.
98CayenneT/A is online now
Old 09-04-2019, 02:31 PM
you're really so lazy you can't do a search...let alone a SIMPLE search as just looking at the top of the page for the stickies?
Circle D and Mrvedit prettymuch wrote it simply enough for anyone with crayons and a kindergarten education could figure it out
Old 09-04-2019, 02:34 PM
02TA3312's Avatar
Well forgive me for wasting you guys’ precious time. Good thing the thread isn’t very long otherwise you might have wasted your whole day..
02TA3312 is offline
Old 09-04-2019, 02:36 PM
02TA3312's Avatar
Was just lookin for some clarity bud. No need for the hostility
02TA3312 is offline
Old 09-05-2019, 10:19 AM
Moderator
mrvedit's Avatar
As the newbie hopefully learned, posting on old threads is not appreciated because it causes everyone who originally posted to get an email update and they then have to re-read the thread to determine whether its an ongoing thread or a long-dead thread.
Therefore, I am closing this thread.
Quick Reply: Difference ?between a lt1/ls1 stall/torque converter
