Yank SS 3600
Yank SS 3600
I was just wanting some opinions I'm considering the Yank SS 3600 in my 01 Camaro SS I recently went with the tsp 224R cam and I love it but is this stall a good combo or is anybody running the same thing?
Personally, I think the SS3600 is too tight for a cam'd car unless you planning on spraying. An SS4000 with 3.73 is going to have pretty good driveability, not to mention your cam will love the added shift extension.
Does it work well on the street and strip? I wonder if it would generate way too much heat while driving down the interstate at 70-80 for long periods at a time... even with a trans cooler?
I have a 4L65E in a low 10 second car and with the right converter and rear end (being built now) i feel i can hit the 9's pretty easy. I currently have a 2800 stall and i think if i crank it up more with the 3.91's in the rear i would be fine. The word ive got is that the higher the stall the more heat and less driver friendly the car is as its still a car i cruise, but not a DD.
For daily driving, I DD a SS4000 in a stock 60e with a 24000 GVW cooler and my trans never sees over 190*F. Heat is the hardest thing on a transmission that sees street use. As long as you get a big cooler and mount it somewhere it will get fresh air you'll be fine. For drag racing these are hard hitting stalls, if you make power and hook you better have a trans that can take the abuse.
