SS3600 install.
Old 06-06-2012, 02:43 PM
Troy5061's Avatar
Default SS3600 install.
Just got done installing my SS3600, I had .255" gap between the stall pads and the flexplate. I doubled up two .070 grade 8 washers on each bolt (ARP Bolts) so I was around .115" for space. Does that sound right, any problems with stacking two washers on each bolt as long as they are the same thickness? Anyone know the correct torque for the converter bolts, alldata says 46 ft lbs so I added a little and did 50 ft lbs.
Old 06-06-2012, 02:56 PM
BAMALS1's Avatar
I think you should be good.
