shifter issues
Old 06-11-2012, 06:46 PM
ricknbird350's Avatar
Default shifter issues
i just installed a b&m ratchet shifter and i was adjusting the cable at the transmission when i noticed over a half inch of play in the shifter shaft going into the transmission. I couldn't adjust it right do to all the play and as i was playing with it i noticed that it started getting worse now i can practically move the shifter shaft without changing gears any ideas of what happened and will i have to pull the trany? or is this something fixable by just dropping the pan?
Old 06-12-2012, 07:02 AM
anyone have any ideas?
Old 06-12-2012, 01:06 PM
figured it out. the nut backed off the shifter shaft where it connects to the rooster piece causing it to not shift
Old 07-19-2012, 10:16 AM
badformulaLS1's Avatar
What model did you use and how difficult was the install?
