700r4 guys, I need to change shift points?!
Old 08-15-2012, 08:11 PM
mcalus's Avatar
Default 700r4 guys, I need to change shift points?!
I have a pro-built automatics 700r4.
I need to change my wot shift points. Its shifting around 4600 rpms and I need to be around 6200.
To my knowledge I need to change out some springs on a side service cover of some sort?
How do I know what springs I need?
Can I get a new cover? The guy that built my trans suggested I get a new cover.
Thanks!
Any help and suggestions or links is greatly appreciated.
Old 08-15-2012, 08:14 PM
Lee12609's Avatar
have you adjusted the TV cable?
Old 08-15-2012, 08:25 PM
mcalus's Avatar
The trans guy might have? I know he messed with the kick down.
What's the tv cable? Sorry for the noon questions. I don't know much about trans's.
Old 08-15-2012, 09:31 PM
lt1-xjs's Avatar
The B&M 20248 kit is whats needed. It takes a lot of trial runs and adjustments. I took the short cut and trimmed coils off the light spring making my 1-2 shift around 6000. I start in 2nd so after the 1-2 I manually shift to 3rd.
Old 10-01-2012, 07:38 AM
mcalus's Avatar
Where can I get a new governor cover?
Edit: anyway I can just put it in drive and go?
Old 10-02-2012, 07:35 AM
mcalus's Avatar
Is this something I should attempt to do? Or have the trans guy do them?
Quick Reply: 700r4 guys, I need to change shift points?!
