leaking front seal
Old 08-21-2012, 05:44 PM
MikeyZ's Avatar
Default leaking front seal
I rebuilt my transmission and has been leak free for around 350 miles now I have a small drip coming out of the inspection hole from the front of the case any ideas what could make it go bad? I had a new seal and new torque converter.
Old 08-21-2012, 05:48 PM
MikeyZ's Avatar
transmission drives fine other wise.
Old 08-22-2012, 07:15 AM
72blownvert's Avatar
Did you replace the pump bushing also? If not that could be your problem.
Old 08-22-2012, 08:19 PM
MikeyZ's Avatar
yes I did.
Old 08-26-2012, 02:55 AM
68_firechicken's Avatar
I had the same thing happen to me but I pinched the seal as I was putting the pump back in. Even though it was small it leaked like crazy.
I took it back out smoothed the sharp edge around whet the pump goes and smothered the seal with some lube and it works like a champ. No leak.
Old 08-26-2012, 11:40 PM
MikeyZ's Avatar
I made sure it went in smooth I also have had 350 mies with no leaks
Quick Reply: leaking front seal
