Swapping 4l80e cases
No, you do not need to do that because then you will kill your transmission. The 94 is an early model 4L80E, the 99 is a late model. Their lubrication systems are fairly different, trying to late/early parts in late/early cases will cause lube failure pretty quickly and your trans will be toast.
