Help- NSS switch install
I removed the old NSS switch off my 2007 4l60e trans, it came with the later 1 connector switch. My harness is setup for the two connector switch. So I've purchase a new one to install. I found some steps to install and was curious if that tool part# "J 41364-A" is absolutely necessary for install?
http://www.electricaladvantage.net/4l60e4l80emlps.aspx
I don't understand your question, the switch is completely independant of the transmission used. Just use whatever switch the harness wants, they both bolt up the same
-I purchased a 4l60e trans from an 2007 Silverado
-The trans came with the later style NSS switch (one connector)
http://www.electricaladvantage.net/4...atedesign.aspx
-My harness is setup for use with this NSS switch for two connectors, so I purchased one of these new.
-I now need to install this new NSS switch onto the 2007 trans, I've already removed the other one that used 1 connector.
-Ive seen some basic written steps to install an NSS switch and it mentions using this "J 41364-A" tool.
-So my question is, do I absolutely need this "J 41364-A" tool for proper installation. And also if there is any other little tips for proper installation so I do it once and not have to redo it all over.
