Stalled 4L60e
Stalled 4L60e
have a yank 3600 in my 02 Camaro ss but I still cant seem to get a better 60ft time then a low 1.8. The car has stock suspension,cam,headers and drag slicks. Any suggestions??
but all of my passes have been 1.8 60ft times. the car doesn't seem to be spinning and it launches right around 3000-3200 but when you let off the gas and your just coasting the car does this strange bucking. but only when your coasting.
the mods are torquer v2 cam unsure of heads think there stock, yank 3600 stall, pacesetter headers ORY magnaflow muffler, trans cooler, hoosier quick time pros 26in tire, has a fast 92 on it but hasn't been tuned for it yet
I went 1.6 consistent on motor with the mods in my signature. Its a good converter imo. I have a whole new setup tho with an FTI. no new track times. Its ok just a little tight. Plan on sending it back to be adjusted a bit.
I also cut a 1.5 60 foot with the yank 3600 on spray.
Some 373s will wake it up for sure. and a torque arm man.
Like I said they tuned it and fixed the power surge but someone told me that when the car is coasting and it starts jerking it could be the torque converter also. I'm gone call them tomorrow.
Thanks for the help. I'll let you know what happens. What all is done to your car what kind of times do you see out of it.
I ran 7.2-7.3s @ 95 1.50-152 short time barely spinning or so with the old 346 combo.. 3500# 2200+da nitrous tune.. 226 cam ls6 intake ported milled 317s ptc 4000. Real budget friendly setup but it performed well.
The current combo is a 370 lq9 based build.. Ls3 top end.. ptc 3500.. 200 shot.
Im looking for low 6s@110 or so on 200 granted the drive line holds up.. Once i get a new trans and rear ill move up to the 300.
