4l80e Shifting With Nitrous
How do you guy's feel about shooting nitrous during shifts whether it's a buildt 4l80e or stock. I know I've read that most 4l60e guys disable there nitrous between shift's by using a window switch.
Thats a pretty vague question can you please elaborate?.?. What are you trying to/debating on doing? A stock 4L80E is only going to take so much and depending upon whats done to it a built one is going to be the same deal. In my opinion if you have to turn the power off to shift something is wrong... A 4L80E is a pretty stout platform and clutches slipping while shifting shouldnt be a concern if its built properly unless you are making pretty crazy power numbers.
Spray through the shifts without a doubt. Best friend has a rcsb fullsize truck, cam and spray with a stock 4l60e shiftkit only. Been running this setup for 3 years, went 11.2@120 about a month ago
