ok to drive with broken top rear torque arm bracket
Old 05-09-2013, 09:26 AM
fst100's Avatar
Question ok to drive with broken top rear torque arm bracket
Currently the top bracket of the factory torque arm broke from the pumpkin but the bottom 2 bolts are still in tact. The pumpkin is not slightly tilted back causing driver side crossbrace to hit the spring on certain bumps. I’m in the process of getting a trans swap and installing a spohn adj. TA but am I okay limping it to my buddies shop?
Quick Reply: ok to drive with broken top rear torque arm bracket
