Suddenly lost 4th gear 4L80E
Old 05-05-2014, 09:27 AM
  #41
Vetal's Avatar
Originally Posted by Jake's Performance
I see it broken in the pictures you posted.
A "pressure plate" is the common term used for the end plate used to hold the clutch pack in place. The clutch is applied by the piston, and pressure from the pack is held by the "pressure plate".
I don't know what the specific verbage used by the manual you are using calls it. I haven't used a manual to build a 4L80E in quite a few years.
The iron piece that is broken off, came off the pressure plate. It is a "tang" that fits into the OD housing and then also the case to keep things from spinning and putting pressure on the bolt (that is broken).
Look at the parts closer and you will see the cause and effect.
Thank you Jake, after that explanation I guess I understood. I was amazed how that small feed bolt could hold OD assembly in place, now that you told that that M shaped tab on the pressure place slides into the case things make sense!
It's the tab I circled with red, correct?
Old 05-05-2014, 11:03 AM
  #42
Vetal's Avatar
While tranny is off and half-apart, should I check and refresh (or get refreshed in a shop) anything else?
Old 05-06-2014, 06:45 PM
  #43
Vetal's Avatar
Couple of OD clutches pics. Look pretty much new except frontmost clutch which has slight wear mark.
Frontmost clutch is .0795 thick and other 3 are .0815 thick.
Should I replace them?
Should I check anything else that can be easily checked while tranny is half-apart?
Attached Thumbnails Suddenly lost 4th gear 4L80E-photo-5-.jpg   Suddenly lost 4th gear 4L80E-photo-6-.jpg
Old 05-08-2014, 10:43 AM
  #44
Vetal's Avatar
Any advises? Can I easily check other clutches at this stage?
Old 05-08-2014, 06:26 PM
  #45
SnIpEz's Avatar
Clutches don't look too terrible.
The only scenario I can really picture causing this was a huge pressure spike in 4th engaged the clutches hard enough to crack the pressure plate. If the force is strong enough to crack the pressure plate, it'd definitely be strong enough to break push the basket enough to break the bolt.
Without knowing what your pressure look like in each gear, it's hard to say. Might not hurt to crack open the pump and check the valves. Check for wear on the pump surface as well.
Old 05-09-2014, 01:56 AM
  #46
Vetal's Avatar
Actually looking closely at that broken tab of pressure plate, I can't see it holding OD assembly against case because tab is only 1/2" wide, while in the tranny case this is much wider (post #41 also shows that)
Old 05-09-2014, 10:44 AM
  #47
SnIpEz's Avatar
Try not to over think it and just take our word for it bro. It gives it a little bit of play, and the pressure plate tab is not as wide as the indentation for it in the case. Totally normal.
Old 05-09-2014, 11:27 AM
  #48
Vetal's Avatar
That's beyond me If it doesn't fit tightly into recession in the case, then the only thing that stops assembly from rotating even .05" is feed bolt. I must be getting smth. wrong then.
Old 05-12-2014, 09:58 PM
  #49
NorthTexasConverter's Avatar
Nope, that's exactly right
Old 05-22-2014, 06:12 PM
  #50
Vetal's Avatar
Having hard time finding 4L80E torque specs, what are torque specs for feed bolt, valve body bolts and pump bolts?
edit: found 18lbs for pump bolts and 17-19lbs for feed bolt
Old 05-22-2014, 10:56 PM
  #51
BattleSausage's Avatar
If you need them, I can/will e-mail a couple of manuals...I rebuilt mine with them. Send me a PM if you need them.
Old 05-23-2014, 06:20 PM
  #52
Vetal's Avatar
I wonder why if I try to turn splined shaft of oil pump, it doesn't move? Is that how it's supposed to be?
P.S. Damn new feed bolt broke when I was just trying to tighten it to 19lbs. Damn. I'll have to invent something tomorrow...
Old 05-24-2014, 07:00 PM
  #53
Vetal's Avatar
I had to make my own feed bolt, hope it's function is as simple as I see it and it will do fine.
Guys is this normal that pump shaft does not rotate at all?
Also, 2 of the pump bolts somehow did not have rubber grommets on them, so now I either have to put them on silicone on top (so they are not submerged in oil), or place them at the bottom so later I can replace them with converter in place (if this is possible at all)
Old 05-24-2014, 07:28 PM
  #54
Vetal's Avatar
Jake, want to double check, can I use John Deere Hygard oil?
Old 05-24-2014, 09:39 PM
  #55
1FastBrick's Avatar
Attached is a good Stock 4L80E manual with flow charts. It's been floating around on the net for some time.
Awhile back someone took 1 apart and did a write up.
Right now this is all I could find.
http://www.performancetrucks.net/for...thread-396429/
Old 05-26-2014, 04:24 AM
  #56
Vetal's Avatar
Can't see any attachments
Good write up!
Old 05-26-2014, 06:20 PM
  #57
No the pump stator is not supposed to rotate, it's a fixed piece. That is normal. You may want to post a picture of the feed hole bolt so we can double check.
Old 05-26-2014, 07:19 PM
  #58
Vetal's Avatar
Here it is, head is a bit smaller in diameter, hope it's fine. Ground down head so that height is almost identical.
Thanks for your help!
Old 05-27-2014, 12:27 AM
  #59
1FastBrick's Avatar
Good write up!
My apologies. It looks like it's too large to upload to the site.
Get it from this thread---> http://www.performancetrucks.net/for...al-pdf-519818/
Old 05-27-2014, 07:50 PM
  #60
Vetal's Avatar
NorthTexasConverter, what do you think of the bolt I made? Should work?
Quick Reply: Suddenly lost 4th gear 4L80E
