wiring info for 4l80E
Newbie here looking for some wiring info. I am doing a swap and doing the harness myself have it pretty well stripped down I have three wires that go to the trans and I don't know gets done with these. these wires are in the fuse block connector LT GREEN,DK GREEN,GRAY. this is a 05 6.0 4L80E. I am assuming I would be able to run the trans with the stock PCM once it was reprogramed. thanks
