Best transmission filter
Moderator
I've seen the GM-spec ones marked as "Made in Mexico" and most aftermarket as "Made in China". I've never bought from an auto parts store, but the ones made on this continent might be better. In either case, make sure it fits snugly into its sleeve; the filter usually comes with a new sleeve if needed.
Moderator
SPX Filtran or Filter Tech are the two that I generally use. I would stay away from the run of the mill part store filters unless they have these names on the filter for either the 80E or the 60E.
