153 tooth 80e Flexplate
I have a LT1 mated to an 80e with an FTI converter in between.
From FTI it has a 6 bolt hookup with a 11.5 and 10.75 diameter patterns. I would really like to use all six bolts but can't seem to find a flexplate that covers both.
Needs to be SFI cert and externally balanced.
I am not sure if the bigger 11.5" bolt circle will fit on the smaller 153 tooth flexplate. I think it will hit the ring gear. You might need to convert to a bigger flexplate and you can find those in a dual bolt pattern. But like Forcd mentioned, 3 bolts holds a lot of power.
Chris
Chris
