After torque converter install HELP!
Ok the car is a 2002 Camaro Z28. Just put a 3600 converter in it and bolted everything back up. Turned the car over and everything is running fine EXCEPT the RPM tach is no longer working. Here's the current situation. I still have it on jacks with no wheels on(checking for leaks and that kinda stuff). I turned it on to make sure I had all gears. It has all gears. The speedometer works along with every other gauge except the stock rpm tach. It sits at 0 no matter what I do to it. The ABS light is on but I don't think that could have anything to do with my problem. So is this just simply a sensor I forgot to plug up when putting the trans back? Or there other things that could cause this?
Update:
Thanks for the reply SSZ. That was the first thing I checked and it was plugged in and looked fine. I ran the computer on it and ended up gettin a code for the cam position sensor. Took the intake off and checked the sensor plug, wires, and it looked fine. Checked every other sensor and wire I could find and couldn't find a single problem anywhere. Bolted everything back up, started it up and it fixed itself I guess. Guess the plug was loose or something, Idk. But its working fine now.
