4th gen 4l60e, will it work in a 2002 1500 4x4?
What year is the vehicles?
if u mean its from a 4th gen fbody it should hook up to a 5.3 or 4.8 with minimal changes but if u mean a 4th gen style 4l60 from something 03 and newer the computer may be different
Moderator
Moderator
The 4WD transfer case requires a very short trans output shaft; the 2WD has a much longer output shaft. And, no, you cannot just cut it down because it would be missing the splines.
