4l80e will not shift after doing the tune for the swap! Help plz
I'm in the same boat as you 100% that I did all steps of wiring properly. Sent pcm to current performance for segment swap. And now I have no speedo, vss code, 1-2 2-3 and tcc pwm codes. And they are absolutely zero help. I had a local guy pull my file. Told me there's a lot of green in the table? He can try to correct it for a hundo. With no guarantee. I'm so po.
4l80e swap help please!
2000 ls1 1998 4l80e ..I wired the speartech speed sensor wires blue and red to pin 22 and pin 23 on pcm red per instructions..and then plugged the harness to the front sensor on trans..and speed sensor still did not work. So I decided to plug the old speed sensor harness in rear sensor and still nothing...what did I do wrong both 4l80e speed sensor are new...
Did you use the original speed sensor plug on the rear (vss) sensor. I plugged the front input sensor to pin 22 and 23 and still nothing ..any helped would be GREATLY appreciated ...thanks
the 4l80e I got was apparently swapped from 4wd to RWD. The rear reluctor ring was missing, so no way the rear sensor is going to work. Look in the hole, where the rear sensor goes, there should be reluctor ring teeth close to the center of the hole. If you only see teeth on the very edge of the hole, you're missing the ring. Good chance if you had a blank sensor in there before, just adding a real sensor may not do the trick.
BTW, mine's also missing the tail housing lube hole.
