TH400 Flex shield
The Bull
Depends, if you are running an Ultra Bell, the answer is you don't need one. If you have the standard bellhousing a CSI flex and drum shield should fit ok. It's tough to bolt on because it takes up the last remaining 1" of space in the tunnel. You may have to do some other work as well. What shield were you looking at using?
I was thinking about using a TCI or ATI sheild. The decision isn't final as I have yet to order my tranny and may default to an Ultra Bell. Thanks for the info.
Are any of you using the adapter plate to accomodate all the bolt holes between the tranny/block? I'm guessing if this route is taken, then wouldn't there need to be spacers for the converter bolts.
