Solenoid B ?
Solenoid B ?
I just had a TCISSF3800 installed in my car last week and now have 6,000mi on my new trany and my solenoid b keep's sticking open what shold i do about this has anyone else had this problem before ?
Seems to be a recurring problem. I don't know if the TC has any effect on the frequency of the complaint or not.
Either way, to replace it you'll need to remove the trans pan. There are 2 solenoids in the very back of the valve body. They are identical! The one on the driver's side is the "A", the one on the pass. side is "B". Simply disconnect the wiring harness from the solenoid, remove the solenoid retaining clip and pull the solenoid out. Reverse proceedure to replace.
If you haven't replaced the filter in the last 20,000 to 25,000 miles, do it now.
Good luck!
Good luck!
