SOLVED - P1SC SD OL 4L60E TransGo Kit w/violent P to R and N to D.
#62
Update on the kit. No issues, nothing is broken and everything still shifts like it should. Only issue is when I am at the track and try to shift WOT in to OD.. I should tune that out but am sure I will burn up every clutch pad in the trans. But I am getting curious, maybe when I have a T56 laying around.
#63
Right after making the 2-3 WOT shift, take the shift lever out of overdrive and bring it back to drive (3rd gear) and you will not have the 3-4 shift occurring. If you have the Sonnax HD 2-3 shift valve installed you can race it in drive without losing apply oil on the 2-3 shift.
