My T56 to 4L80E Build
Still collecting parts. I've got a converter since the last post. Went with an FTI billet triple disc lockup 3600 stall per FTI's recommendations. I was thinking higher stall initially but was convinced by FTI that at my power and higher the stall effectively is closer to 4k stall give or take. Regardless I'm sure it'll be great. I'm going to be getting the mezier flexplate from FTI soon as the next part then I think I've decided on the pro ratchet shifter. After that I'm thinking of going with the compushift2 controller and then whatever smaller odds and ends I still need. Back yard projects have been making it hard to gather these parts faster but its getting closer.
Thanks for posting pics of the shift cable guys. I didn't know that there was an issue with that brace needing to be cut. I'm going to try to mount my shifter back far enough without it looking bad to avoid any unnecessary cutting like the last guy did. Already not looking forward to cutting the frame for the plug but it is what it is I guess.
Any pics of how you mounted the shifter to clear that brace without cutting?
I don't Know if you can tell but the rear of the shifter is mounted on the cars trans tunnel where it goes up about an inch, and not the hole cover I built. It mounts the shifter pretty far back but it was the only way I could get the cable to work with out cutting the brace. I put a few washers under the front 2 bolts to kinda raise the shifter cause the rear is higher.
Update, shifter came in today. Decided on the B&M Pro stick since I wasn't sure if I'd be ok with a ratchet shifter in the long run for mostly street driving and also the Pro Stick shows as compatible with the 4l80e. Also got a billet Phoenix shift **** for it. The threads dont match but I bought a pack of thread adapters and 2 of them back to back inside of the **** mates up perfect with the the shifter. I was surprised actually by the final fit, the shift stick has these blocks that come out after the threads which actually stop the billet **** in the perfect position so the phoenix will face the right way. Here are some shots:
Also, I believe i read on this site that the harness out the side of the transmissions required some cutting. Anyone got a few pictures with different angles?
I just started this yesterday. So i will have alot of questions as I go along. I see you guys only cut the brace in the tunnel at that spot, i figured there would need to be a little more hammering to make the trans fit?
#33
Not yet haven't gotten under the car, still gathering parts feels like it'll never end. I'll be ordering a flywheel this weekend most likely.
Since I'm still gathering parts, I recall seeing somewhere that one should order a stronger joint for the driveshaft. Anyone got any part numbers or links?
NnOoSsSs please be sure to post up pictures as you go along. I'm sure I'll need em when its finally time for me to get in there.
#34
#35
I'm thinking Flywheel this weekend, smaller odds and ends in the months to follow and then compushift2 during tax time at which point I'll hopefully have everything I need to start the 80e swap. I'd love to just keep it sitting and build up an engine but I'm worried that'll take too long and I dont want the tranny sitting for years without lubrication flowing through it at least every now and then. What other parts have you had to pick up? I'm sure I've overlooked something that I'll need.
#36
So far the plan is to get a compushift 2 to handle the shifting. Want to go that route because I think it'll be fun later on to get paddle shifters setup in the car and the compushift 2 is capable of handling that.
This was yesterday.
#38
Gotta say man, jealous of your garage space and lift access. I'm going to try to do the install on my own when the time comes and I foresee a crawler in my future.
#39
Yea APS twins on a completely stock LS1 except for the intake manifold (Vic Jr w/ sharp/shorty elbow). I've got a huron speed twin kit I'm fixing to install. Much like my transmission efforts I'm still collecting parts on that but the transmission takes priority right now. Ultimately I'd like to build an LSNext (thinking 364 to keep it emissions friendly-er since I still have to deal with all that) by the time i get to setting up the huron speed twin kit.
