torque converter issue
Old 02-23-2015, 04:07 AM
gtfodave's Avatar
Default torque converter issue
Hey guys, having a slight fear my torque convertor may be on its way out.
When the convertor locks up and I'm slightly on the throttle or just idling at a higher speed (50) I feel a slight lugging or jerking in the car. First stalled auto car I've owned but I know the concept of a triple disc lockup, it doesn't feel normal at all. Any ideas or places to start?
Old 02-23-2015, 11:00 AM
Moderator
mrvedit's Avatar
Do you have a cam in the car?
If yes, this sounds normal. In many cam'ed cars you need to increase the lockup speed to prevent the lugging.
Old 02-23-2015, 02:38 PM
gtfodave's Avatar
So change the speed the lockup kicks in at or is this something different
Old 02-23-2015, 03:04 PM
nj02z's Avatar
Mine will do that also if lugged.
Old 02-23-2015, 04:57 PM
Moderator
mrvedit's Avatar
Yes, determine at what RPM the engine stops lugging and set the lockup speed to that or a bit above. Obviously you need tuning software or have a tuner do this for you.
Old 03-01-2015, 11:49 AM
dreww's Avatar
I believe I had a stock tune on my car when I got it. It did have a stall convertor put in right before I bought the car.
It did need some tuning to fix all the stall convertor "side effects". I had to raise my overdrive lockup from 45mph to 55mph. Even with stock 2.73 gears and stock cam locking up at 45mph caused some issue. I raised it to 55. made a world of difference.
Old 03-01-2015, 11:53 AM
gtfodave's Avatar
Thanks guys yea it seems like it's more normal than I thought. I'm gonna have famato raise the rpm and lockup a little then
Quick Reply: torque converter issue
