Motor home 4l80e
Old 03-12-2015, 03:45 PM
FormulaTA327's Avatar
Default Motor home 4l80e
Would a 4l80 out a 2000 motor home work for my 2001 formula. The guy selling it says it has straight cut gears. Is the shift linkage or anything different about it compared to a 2500 truck.
Old 03-12-2015, 11:24 PM
zgp
zgp's Avatar
It is the same except the tailhousing and output shaft.
They did come with straight cut gears. the code on the tag should be a DNP model.
Old 03-13-2015, 01:50 AM
with that tail housing would it still be ok to install or would I need to find a different housing
Old 03-13-2015, 10:07 AM
Mystery Bird's Avatar
Is it behind a diesel? I believe they may be different. If or what the difference I don't know but I do remember something might be different.
Old 03-13-2015, 02:41 PM
I may end up having to use a core from the shop then.
Old 03-15-2015, 07:45 PM
aknovaman's Avatar
Diesel have very low stall speed converters.
Old 03-15-2015, 10:54 PM
I wouldn't use the converter that came with it, I'm using a circle d 3500 stall.
Quick Reply: Motor home 4l80e
