4L60e or TH400?
4L60e or TH400?
I've been tossing around the idea of going to a built TH400. I currently have a FLT level 4 4L60e and I love it, it does it job and has never skipped a beat.
BUT, I want to get full potential and since I just got my MWC 9", I'm thinking of a trans brake and spray off the line. So I'm just trying to weigh out my options on what to do. I have a PT4000 stall and 3.89 gears with 275/50 MT DR's.
I would like to hear some pros vs. cons from you guys who have personally switched from a 4l60e to a TH400. My car is a weekend toy and I take it to the track a couple times a year which is almost a 4hr round trip. Any input I greatly appreciate!!! Thanks
Moderator
With 3.89 gears you will be running 4000 RPM on the highway with the TH400. That sounds awful for a 4 hour trip.
I think an FLT level 4 should be able to handle 600HP, but why not call them to be sure and perhaps get some suggestions on how to extend the life.
What kind of times are you running now and how much spray are you thinking?
Mainly because cost and the weight factor.
Price I can understand though. I would save more however if you really are going to be on the street that much on the weekends and have to make such a far away drive.
Weight difference between an 80E and a TH400 is negligible at best. ~35 pounds? When you have overdrive and lockup, that's more than fair as a tradeoff.
Thats what I want, is that t-brake. But I think whenever the times comes and my car is strictly a drag car, then a th400 it is.
I do like to make long trips at times, so I guess that OD is keeping me sane from higher rpm cruising.
Yeah I think it's Rossler with the trans brake? but damn its $$$$ lol.
Haha, I have been talking to my wife about getting a tow rig/trailer to have on hand. I know it would be used a lot!
I guess its what you feel comfortable cruising at and driving around. On my car the 4l60e is excellent in driveabilty and performance. I've had a 400 on a different car but was not fun as a daily or cruising. My 4l60e also runs a 4000 stall lockup and I run single digits on the nitrous. I would never go back to a 3 spd auto.
th400.
4l60e's are JUST good enough, for a stock, unopened, untuned ls1.
trans shops can sell level 1 or level 100000000 all they want. ill smoke the 3-4 clutch pack first drive if the torque management in the pcm is tuned out.
4l60e = JUNK
4l60e = JUNK
My 68,000 mile 4L60E was stock at first with a shift kit and a yank 3200 convertor, had it in my Mustang for about 9 years. ran 11:40's all the time and 10:60's with nitrous for all those years. front pump went out once and shift solenoid once also. Now I'm running a built 4L60E with a 4000 stall lock up convertor and can drive it anywhere, runs 10's on motor and then I have 2 stages of nitrous which brings me to single digits.
Yes the 4L60E is a weaker trans then a 4L80E or a turbo 400. Heck I remember when powerglides were thought of as a junk anemic transmission. But as technology changes and people learn more tricks these trans are getting better and stronger.
it all depends ones tolerance. i switch from a 4l60 to a th400 with a tb about 3 years ago and mines sees a lot of street time when weather permits. My car sees the track at least once a month sometimes more and its never missed a beat . From what iv seen you will always have 4l60s that can get you low numbers but the question is for how long and i think thats where the 3speeds and 4l80s separate themselves. I can tolerate the higher cruising rpms in return for more reliability
With your 26" tall MT you'll be around 3500 at 70mph with a non-OD trans like a 350, 400, or PG. If you can run a 28" tire you'll only be at 3300rpm @ 70mph, which isn't too bad if its not a daily driver and won't see the highway too often.
I'd go with the bigger trans, too many people settle into rebuild cycles with 60e's and TH350s and spend all this money going through multiple trans when they could have just went to a stronger unit in the first place. The extra weight and drivetrain loss is worth it IMO...I'd take a tenth hit to my ET to not have to worry about tearing down a trans every year.
I was in your same spot as I started planning my build. What I came up with was to get the 4L60 built. You can spray out of the hole.
4L60- I don't need another stall, least parasitic loss, lightest, moderate build price, O/D and can run a higher gear ratio.
TH400- Relatively cheap to make bullet proof, no OD, no lock up, T brake is awesome, would suck with a 26" street tire.
4L80- Best of both worlds in terms of reliability and streetability, expensive as **** to build, heavy, T brake isn't as reactive as on TH400.
Since I decided to get my 4L60 built I don't have to change much, it isn't insanely expensive and can handle a lot when built right.
