Trans Advice on LQ9 Swap
Hi all,
I have an 51 Mercury M5 cabover and I have a deal pending on an 2003 LQ9 with low miles I would like to swap in. My problem is the transmission. I would like a 6 speed over a 4 speed as I intend to use this truck to haul a vintage trailer. As I understand, the 6L90 will not work with this older engine and I might be limited to either a 2006 or later Allison 1000 or using a 4l80E with an over/underdrive from gearvendors or something.
Does anyone know if an Allison can be made to work with this engine? I would like to avoid the additional cost of an over/underdrive if I can but I haven't been able to find an answer either way using the google.
Moderator
The 4L80E has an overdrive 4th gear; you would need need a gearvendors unit. A 6L90E has a wider gear ratio range. It will bolt up to any LSx engine, but you need an expensive aftermarket trans controller from PCS to run it.
Well, that's a bust.
"Thank you for your interest in PCS products. We don't support the GM 6L transmissions or Allison transmissions with harness or caibrations. Our TCM-2650 is a controller available to vehicle manufactures and OEM customers only. Sorry"
