Metal trans cooler line leaking
No idea if the dealer can still supply replacement lines.
I Googled "auto transmission line tubing" and found a few potential sources including pre-made braided lines and videos using bulk tubing from the local auto store.
Let us know if you find a source for pre-bent replacement lines or how you ended up replacing them.
I spilled some transmission fluid while flushing the radiator's transmission cooler during a rebuild and now I get to do some detailing work again.
The cooling lines do not get the full line pressure of the trans, but perhaps half the pressure; so a max of 120psi with a shift kit and a max of 100psi without.
I know that some aftermarket coolers are installed with rubber lines; while they would give me pause, I know that they usually work just fine.
It could be the installation or the quality of the hoses that failed for you; I don't think the shift kit or higher line pressure had much to do with it.
Good luck getting all the leaks fixed. Personally my trans and PS lines are all teflon AN lines.
but i would get some nice braided lines if i was to replace it again, they look really good also
Check for any place that hitting bumps in the road could be smacking the rubber against a harder or sharp area.
look for anything the rubber hose is laying on, take a larger piece of hose and cover it in the area if found
(slit a larger one down the side, and literally cover the old rubber hose)
make sure absolutely nothing is touching any side of that rubber hose, vibration and friction will find its way to your fluid (through cutting ;] )
so moral of the story is, nothing can touch those lines (friction is a
