Ballooned converter?
Old 07-08-2015, 10:58 PM
maxspeed05V's Avatar
Default Ballooned converter?
Going to try to keep this short
On the ride home from my last dragstrip night I had a terrible driveline vibration , actually drove in 3 for about 50 miles just cause it was worse during lockup.
Then as I kept driving 90% of the vibration went away, now just a few weeks later the vibration is back but not as bad.
Not sure if it's related ,
I also noticed some fluid seepage from the trans pump area in the bell housing which is new , the trans only has about 2000 miles on it since the rebuild .
My first guess is a ballooned the converter, anyone else have any ideas ?
Old 07-09-2015, 09:12 AM
Moderator
mrvedit's Avatar
Hard to be sure, but here my guess:
I would first suspect the front trans bushing; this is the bushing pressed into the pump. As the converter wobbles in that worn bushing the outer seal will start to leak a bit.
While the seal can be replaced from outside the trans, replacing the bushing requires removing the pump.
Old 07-09-2015, 10:41 AM
Would there be any way to see if the converter is ballooned through the bell housing inspection hole ?
I'm thinking of watching it while in park or neutral, but I'm not sure what To look for.
As far as the leak, it seems to start with the vibration- the transmission is a rpm level 6 with approximately 2000 miles . Which is what leaks me to believe the converter has a problem
Old 07-15-2015, 04:52 PM
forcd ind's Avatar
Does it vibrate in neutral?- if it does you could try and unbolt the conv and
push it away from the FW, then start it and see if it still vibrates
Also a good time to see if it did balloon a little
Also ck your driveshaft at the rear yoke, and front yoke play
Old 07-15-2015, 06:06 PM
drew408's Avatar
If your Convertor ballooned,it'd take out your thrust bearing in the engine 999 times out of 1000. I'd look elsewhere.
Quick Reply: Ballooned converter?
