Pull the tranny to finish Transgo Hd2 4l60e?
Reading the instructions it says I have to put springs in the pump for anything over 5500 rpms, now I'm getting it tuned and he said it'll be at 6,000. Now would I have to pull the tranny out to put the springs on or will I be okay? Just did the springs in the accumulator and valve body. Nothing crazy.
I run this same kit in my A4 (mods in my signature). I did not pull the tranny to install them. Just do the basic install and you should be fine. I have ran mine with no problems. I shift at well over 5500 RPM. It makes a huge difference. Shifts firmly and quickly.
I was gong to go get a stall and replace flywheel and all that simple stuff, and replace most tranny parts with updated high rating hp before I pulled the tranny to change those.
