Fuddle 3600?
Fuddle 3600?
Anyone know anything about these converters? I've got one I've never used it though would it be okay to use till I can afford a better one ? The motors already out so it'd be an easy upgrade over the stock converter.
Moderator
There were a couple of versions. I have the "HP/Street"
for its beefier lockup clutch, and it's served me well. I
have no useful opinion on the base model nor the one
that was supposed to be more for racing.
I also had my build bent toward efficiency with low STR,
you could order what you wanted from them - which
means that aside from it being 3600 nominal stall speed
you may not know much about other attributes - like
efficiency and the profile of torque multiplication vs RPM
and input torque.
As long as you know it's clean (not pulled from a failed
trans, maybe holding trash) I'd go for it, see if you like
it enough to keep.
and input torque.
it enough to keep.
